Calibra steering rack removal question?
Does anyone know a good way to get the bolt out from between the servo and rack? I have managed to get a 3/8 13ml between but it doesnt seem to catch the bolt so I cant even tell if the socket it right. All the other bolts are off and they are 13ml. Any one done this before? I cant get the servo off as there is no space to manouver and the bolts for it are behind the servo and not behind the bulkhead/footwell making it 10x harder.
I only have two bolts left and its annoying me now
Sean
SE5 Turbo
LE 07
LE 16
LE41
Turbo
Another Turbo
Se7
V6
16V
16V XEV
8v
SE5 Turbo
LE 07
LE 16
LE41
Turbo
Another Turbo
Se7
V6
16V
16V XEV
8v
- Gold Member
Re: Calibra steering rack removal question?
i put a pinch bar under the master cylinder and the top of the wing and pushed down a littel giveing me enough room to get it out
I'll try that. Just found my manual which says to take out the wiper and there are two mount bolts behind the bulkhead. I'll see if I can lever it first as you say then if that is too cramped I'll go for plan B thanks mate.
Sean
SE5 Turbo
LE 07
LE 16
LE41
Turbo
Another Turbo
Se7
V6
16V
16V XEV
8v
SE5 Turbo
LE 07
LE 16
LE41
Turbo
Another Turbo
Se7
V6
16V
16V XEV
8v
- Gold Member
se5 wrote:Just found my manual which says to take out the wiper and there are two mount bolts behind the bulkhead.
Thats what I do
