Eddey's V6 - The Ghost...
Re: Eddey's V6 Profile
by EddeyDancer » Wed Nov 02, 2011 8:34 pm
I removed the 'Old' damaged V-Grille today... :doh:
I also prepared the newer undamaged V-Grille, for fitting on the SMK Bumper!
It certainly lost some of it's distinct 'Calibra look' without it... :think:
Which do You prefer??? :whistle:
by rich30mex » Wed Nov 02, 2011 8:48 pm
Without for me sir
Events Coordinator
Events Coordinator
by Fraz » Sat Nov 05, 2011 10:57 pm
without and a bit of mesh in there
by leelee » Sat Nov 05, 2011 11:31 pm
I prefer without the v grille
by EddeyDancer » Sun Nov 06, 2011 7:18 pm
The V-Grille is a Distinct Post 1995 Calibra feature!
That's actually one of the main reasons, why I chose to put it back on...
Being that My Front Bumper is NOT the Original one, I wanted to Upgrade the look, but maintain the Calibra traits...
Same concept goes, with the Rear Badges...
I prefer to keem them on, as I want people to know it's a Calibra! Instead of them asking Me: 'What's that Car??? :doh:
by Fraz » Sun Nov 06, 2011 8:14 pm
Got all the badges on mine at still get asked that question, still think it looks better without it ...looks more menacing
by v6 steve » Sun Nov 06, 2011 8:25 pm
with out
love taking it in to vauxhall and the young parts guys asking what is it
by craigyboy » Sun Nov 06, 2011 9:59 pm
I would keep it Eddey ive always thought that the
v grill was a nice little touch :handgestures-thumbupright:
by EddeyDancer » Tue Nov 08, 2011 4:34 pm
Fraz wrote:Got all the badges on mine, and still get asked that question
Really??? That's SHOCKING being that Calibra, are quite common in the UK :shock:
by Fraz » Tue Nov 08, 2011 5:16 pm
not that common, old cars now and a lot of people have never seen one ....heard of it maybe but not actully seen one
Eddey's V6 SHIPMENT
by EddeyDancer » Mon Nov 14, 2011 3:23 pm
*** FINALLY THE SHIPMENT HAS ARRIVED!!! ***
After spending nearly all of 2011 shopping and importing, the Shipment is here!!!
It's taken alot longer than first anticipated, but I wasn't in any great hurry either...
There'll certainly be some ACTION happening in my garage, over the next few months!
Anyway, I finally finished checking, unpacking everything and cleaning up most parts...
There ended up being more three times as much packaging, than there was actual parts! :shock:
But I'm very pleased and excited with everything, and nothing was damaged in Transit!
The 3 Phases are: Interior, Motor and Suspension...
I'm hoping to get motivated, and have most of the work done, by the end of January 2012
Eddey's V6 - More LED's
by EddeyDancer » Tue Nov 15, 2011 8:52 pm
Yesterday I fitted some more LED's...
The Red Bulbs I put into the tail lights, provided a much better tone of Red than the Standard Bulb...
The same thing goes with the White Bulbs, that were fitted into the Reverse Light sections...
I tried the White Bulbs in the Rear Fog section, but the Red Bulb gave a better tone of Red...
The only issue I had with the LED's in the Tail Lights, was with the Rear Indicators!
I fitted the LED's in the Front Indicators with the 'Flasher Fix Relay' and they worked fine!
But when I fitted the Rear Indicator LED Bulbs, there were issues... I suspect that the 'Flasher Fix Relay' is not up for it!
So I'll look into that at some stage, but for now the Standard Indicator Bulbs will do!
Eddey's V6 - INTERIOR UPGRADE
by EddeyDancer » Sat Nov 19, 2011 7:51 pm
COMMENCED THE INTERIOR PHASE!!!
Yesterday I spent about 12 hours working on the 'New Look' Interior Upgrade...
I 'Stripped and Cleaned' most of the Interior, being seats, centre console, door trims, pillars, boot trims and headliner!
I then went over everything in great detail, and tightened any loose screws and replaced the many broken/damaged clips!
I also located the 'Heated Seat' wiring beneath the carpet, replaced the 'Boot Inner Trims' and replaced the Sunroof Motor!
So now I just need the Head Lining re-done, and then I can start putting things back together again...
Being a Perfectionist, I like to take my time and do things properly... But it's looking heaps better already!
Eddey's V6 - LED's fitted in Dash
by EddeyDancer » Mon Nov 21, 2011 1:14 am
Commenced the White LED Dash Upgrade...
The improvement was instant, and the Photos will confirm that my effort was worthwhile!!!
I also discovered that the suspected blown bulb in the 'TC Light' in the Instrument Panel, actually had NO bulb in there! :evil:
The Dials took 4 White LED's, but I also placed a few more LED's in the 'Mostly Used' sections of the Instrument Panel...
The Job really wasn't as difficult, as I was expecting it to be... :dance:
by EddeyDancer » Fri Dec 02, 2011 6:03 pm
The Interior Phase had to be put on hold, as the Roof Liner was at the Trimmers...
So I thought I'd try and remove the Throttle Body and Traction Control Motor, without removing the Manifold... FAILED!!!
But this actually turned out to be a good thing, as I ended up removing the Manifold and did a Very Detailed Service!
I was so determined to finish this Job, that I stayed in the Garage for 16 Hours... 15:00 - 07:00
I took My time, being it My first attempt at removing the V6 Manifold, but I did a Top Quality Job...
STAGE ONE: V6 Manifold and it's Components
1 - Removed and Stripped the Manifold
2 - Thoroughly Cleaned the Manifold with Carbi Cleaner
3 - Thoroughly Stripped and Cleaned the Throttle Body
4 - Thoroughly Cleaned the Replacement Traction Control Motor
5 - Thoroughly Cleaned the Replacement Idle Control Valve & Hose
SUMMARY: Service done @ 173,770 Km
I finally decided to have a go at removing the V6 Manifold, and I'm so glad I did...
I gave everything a good clean up, and detected a few areas needing attention...
I took it for decent test drive, and it's running so much smoother than ever!!!
I was going to try fitting the Lower Divider, but one step at a time I think...
Even with some slight concerns at times, I'm very pleased with how it all went...
