REAR SPRINGS PAD BUSH KIT
Has anyone fitted these, or anything similar to the Calibra???
They come in the following sizes: 6mm, 8mm, 10mm and 12mm
Any information will be much appreciated...
http://www.ebay.com.au/itm/WHITELINE-VA ... 4160f80964
Re: REAR SPRINGS PAD BUSH KIT
What do they do?
Mark1 wrote:What do they do?
I think they are fitted to adjust the ride height, with Lowering Springs...
But is there any such a part, fitted to the Calibra Rear Springs as Standard???
As My Rear Springs don't appear to be level, and was wondering if this might be the cause!!!
They fit under the rear coil spring. I made them out of a bit of 6mm conveyor belt to help reduce the rear camber until I can alter the suspension arm.
Alan
Alan
- Gold Member
vec 160 wrote:They fit under the rear coil spring. I made them out of a bit of 6mm conveyor belt to help reduce the rear camber until I can alter the suspension arm.
Alan
Did You do the 'Rear Springs' Job Yourself?
I was wondering if there are any of these fitted already, as Standard at the Rear Springs???
It can be seen clearly in this photo, at the base of the spring...
I just bought a Pair of these Whiteline 12mm Pads for $57.51
http://www.ebay.com.au/itm/161829259991 ... EBIDX%3AIT
- Attachments
- Rear Spring Pads.jpg (8.6 KiB) Viewed 46513 times
EddeyDancer wrote:I just bought a Pair of these Whiteline 12mm Pads for $57.51
So I recently fitted some New KYB Rear Shocks with K-Mac Springs...
Being that the Springs lowered the car too much, I fitted some Whiteline Rear Spring Pad Bushing, to adjust the ride height, to my liking...
I'm really pleased with the Performance and Looks...
viewtopic.php?f=16&t=45499&start=315
Original Rubber pads are still available
part # 90447199
part # 90447199
callyman wrote:Original Rubber pads are still available part # 90447199
I used them in addition to, not as replacements, to adjust the ride height...
Users browsing this forum: No registered users and 114 guests
