Opel Calibra Last Edition Nr.0462 * 400+ hp
Re: Opel Calibra Last Edition Nr.0462 * now with Turbo
by D-Man » Thu Jul 12, 2012 7:46 pm
Fraz wrote:is that not one of the Lenk number plate surrounds
No mate, this is original GM part ;)
I've only tinted it black.
EddeyDancer wrote:Mate...
From where you get the Number Plate Surround???
I must get one for My Beautiful Calibra, here in Australia...
I got it from one lad on a local Calibra forum for a bargain :)
They used to appear on a German eBay, but usually are sold for a crazy sums
by D-Man » Fri Jul 13, 2012 7:57 pm
Above mentioned missing part is got. Also found out, that I need more than just dash...
by D-Man » Sat Jul 21, 2012 8:39 pm
F28 has been mounted and it was discovered, that gearbox has it's usual problem - crunching 2nd gear... However I've managed to find new original synchromesh gear rings.
So do hope my gearbox will work fine soon.
Meantime also tx box has been reinforced in swedish style :) Will get it cooled as well soon.
by D-Man » Mon Jul 23, 2012 10:40 am
Got my synchro today. Brand new, original part 8)
by Fraz » Mon Jul 23, 2012 1:05 pm
good luck with stripping down the gearbox...done a few (not F28) and its great fun
what more than just dash ..mean then??
and what is this Swedish style then??
why cant you use your cruise control now ??
by D-Man » Mon Jul 23, 2012 1:28 pm
Fraz wrote:what more than just dash ..mean then??
I also need a least ABS from later turbo engine (with 25 pins)
I've read that cruise control won't work with elec. speedo on speed over 50mph :think: ...
by Fraz » Mon Jul 23, 2012 3:47 pm
I thought it was depending on which CC you used ...Carlton/senator or Omega Vectra
by Fraz » Mon Jul 23, 2012 3:54 pm
just had a check and it does say on teh guide I have
Fitting Cruise Control to the Cavalier/Calibra from a Carlton/Senator
WARNING DOES NOT WORK ABOVE 50 MPH ON L REG AND NEWER CARS
CONSIDER FITTING A VECTRA/OMEGA SYSTEM
by D-Man » Mon Jul 23, 2012 4:11 pm
Mine is from Carlton/Senator.
Will have to take a look on how to fit newer cruise control from Vectra.
by D-Man » Sun Oct 21, 2012 1:10 am
After being traveling with a car (not Calibra, just rented TDi) in different mountain areas I guess I have to go for a biturbo 8)
Luckily we have had a positive experience with biturbo setup on Calibra before.
by saunders » Mon Nov 05, 2012 10:20 pm
Will be an animal
saunders
by D-Man » Tue Nov 06, 2012 9:57 pm
saunders wrote:Will be an animal
I hope so :)
The Beast in a beauty's dress :lol:
by Callyman » Tue Nov 06, 2012 10:27 pm
I hope so :)
I've met a few of them in my life. :lol:
by D-Man » Thu Nov 08, 2012 9:50 pm
We have not so much sleepers here in LV 8)
by D-Man » Wed Nov 14, 2012 2:32 pm
Couple of new bits arrived:
- Bosch 300lph fuel pump
- Reinforced Sachs Performance clutch cover
- one more 1st-2nd gear OEM synchro, as I decided to refurbish whole box, and not just change one crunching 2nd gear synchro
Next step - 5 bolt wheel hubs from later Calibra/Vectra, SAAB/Vectra GSi caliper holders and 3xx brake disc to the front.
BTW if anybody has used SAAB/Vectra GSi calipers for sale - please let me know.
100GBP for new set from LMF is not an option for the time being.
Users browsing this forum: Bing [Bot] and 19 guests
