overhaul begins
overhaul begins
by craigyboy » Thu Jul 26, 2012 10:47 pm
Se6 rear subframe stipped off for re-furb and underfloor treatment
Re: overhaul begins
by vec 160 » Fri Jul 27, 2012 4:15 am
Lots of corrosion on that subframe.
Nice to see that I am not the only person that carries out most of the work in the fresh air.
Re: overhaul begins
by craigyboy » Fri Jul 27, 2012 2:50 pm
vec 160 wrote:Lots of corrosion on that subframe.
The sub frame will be getting rubbed down and painted in
the garage mate.Times like this I wish I had a bigger garage
to get alot more work done.
Re: overhaul begins
by Fraz » Fri Jul 27, 2012 4:42 pm
doing well there Craig, I gather new bushs etc will be fitted? you doing polly ones on that as well
Re: overhaul begins
by calibre ray » Fri Jul 27, 2012 6:11 pm
you dont hang about do you. good work there ive got all that to come twice yet :shifty:
Re: overhaul begins
by craigyboy » Fri Jul 27, 2012 6:40 pm
Fraz wrote:doing well there Craig, I gather new bushs etc will be fitted? you doing polly ones on that as well
Yes Fraz, the only thing is they dont come too cheap.
Needs a bit of welding work done on it to
Re: overhaul begins
by v6 steve » Fri Jul 27, 2012 6:57 pm
???? the subframe needs welding ?
are you going to paint it or powder coat it ?
Re: overhaul begins
by craigyboy » Fri Jul 27, 2012 7:20 pm
Just goin to paint it Steve.If you look at the second pic
you can see the bit under the arch that needs welded
Re: overhaul begins
by KERR_SE9 » Sat Jul 28, 2012 3:38 pm
Good to see this is getting some deserved tlc
Re: overhaul begins
by craigyboy » Sat Jul 28, 2012 7:51 pm
KERR_SE9 wrote:Good to see this is getting some deserved tlc
Already went through one wire brush attachment
for the grinder trying to clean up that subframe
Re: overhaul begins
by v6 steve » Sat Jul 28, 2012 7:58 pm
would you not be cheaper quicker and better finish getting it blasted
Re: overhaul begins
by craigyboy » Sat Jul 28, 2012 8:13 pm
I should have maybe looked into that mate
Re: overhaul begins
by big_gordy » Mon Jul 30, 2012 7:01 am
good work craig looking good
Re: overhaul begins
by MadOnVaux! » Mon Jul 30, 2012 3:24 pm
Yeah great thread, very interesting to see this progress :)
Re: overhaul begins
by Allys Cally » Mon Jul 30, 2012 5:29 pm
i'd have to agree with Steve you'll get a far better finish with it sandblasted mate, there's a place down our way that does it and their quite reasonable. if your interested let me know and i'll send you their details
