progress of my calibra
Re: progress of my calibra
17in BBS's now fitted
looking very nice
Looks well pal
Phill wrote:Is that your car in tv this month Ally ?
yeah mate in the Hall Of Fame section
well today i fitted the braided fuel lines, so no more leak at the fuel rail
also i hated seeing the black air flow meter in between the two red hoses, so decided to give it a lick of paint
so today's job rear brakes (might i add i hate doing rear brakes) i bought everything last year before the car went off the road with intentions of doing it over the winter.
things didn't quite go to plan and the car went away to get paint work done instead. so back to today
the discs were a sorry sight
after much hammering and swearing i finally got the old discs off, the pads basically fell apart when i took them out the caliper
i had painted the discs yesterday but ended up giving the backing plates a rub down and another coat for protection
so now fitted with some drilled and grooved discs the same as the front
looks good ally
distinct lack of under seal in those arches though
much better...and I also use the buckets as a work bench
