been a busy boy
been a busy boy
As most of you know the LE had wee oil problem as in it wasnt being pumped round the engine it was just getting pumped straight back into the sump with out getting any where else, which resulted in the bottom end rattling about like a tool box falling down a set of metal stairs, so iv had to push the winter rebuild forward and hold back on some of the mods till later,
engine out
new engine after a clean and paint lots of new parts so should go well
just need to get the rest of the bits back on and back in the LE
engine out
Re: been a busy boy
Looking good pal is the other engine fooked then or can it be sorted at a later date
Re: been a busy boy
rich30mex wrote:Looking good pal is the other engine fooked then or can it be sorted at a later date
its stripped down and in a big box under bench for an other day might be going in the corsa if shane gets his finger out and buys an other car
Re: been a busy boy
Good work Steve.Where did you manage to get the other engine from?
Re: been a busy boy
Looks good Steve
Re: been a busy boy
Nice work Steve.
been a busy boy
Good work chap, it looks a thing of beauty
Re: been a busy boy
looking good mate i'll get a better look just shortly
been a busy boy
craigyboy wrote:Good work Steve.Where did you manage to get the other engine from?
Some poor nova or corsa probably
Praise the Lowered !
Re: been a busy boy
been a busy boy
been a busy boy
