Body Kit fitted
Re: Body Kit fitted
Good to see a "non-busted" front splitter again mate!
Calibra SE4 3.2 V6 + F28
A Couple of German Cars!
Body Kit fitted
Lol
Bit of a mini meet, photo session yesterday with Sealysonic and BadKid
BadKid will be doing a thread soon no doubt but here are a couple of quickies I did
Re: Body Kit fitted
Nice
Re: Body Kit fitted
looks good hun
Re: Body Kit fitted
Great time was had....however all i can think of is bigger wheels and body kits now lol DAME YOU TREND SETTERS !!!!! lol
sealeysonic
Re: Body Kit fitted
sealeysonic wrote:Great time was had...
however all I can think of, is bigger wheels and body kits now lol DAME YOU TREND SETTERS !!!!! lol
Mate, I think that the SE6 would look great, with a decent kit and set of wheels!!!
Re: Body Kit fitted
Spent some time trying to figure out why the n/s rear seatbelt is wet
Finally discovered that the numb nuts who sprayed the car didn't tighten up the nuts that hold the n/s rear window in so rain has been running down the weather strip and seeping in at the corner of the window into the compartment in the boot where the seat belt is installed
Re: Body Kit fitted
Looking good fella. great looking bodykit for the calibra in my opinion. def need the skirts to match now and at least 17" wheels to finish the look. Not sure about blending the kit to the body as i think theres always a chance of cracks appearing along the joints as the panels flex.
Body Kit fitted
Installing new rad today , unfortunately new rad is useless as it doesn't have the connections on it for the pipe work for the secondary water pump
Body Kit fitted
Unless suppliers have an alternative, I'm looking at a recore
Re: Body Kit fitted
You can swap the side tanks over...
A mate recently had this same issue...
I sent him over the side tank, with the 'Aux Water Pump' fitting...
He heated it up in the oven, in order to fit in back onto the Radiator Core...
Also, I once scored a Radiator off a V6 that didn't even have a fitting for the Aux Water Pump...
It being so cold over there in UK, perhaps it might not be so necessary to have the AWP connected...
Re: Body Kit fitted
Re: Body Kit fitted
While the rad is out might as well remove the front a/c rad as it's all disconnected anyway
Re: Body Kit fitted
couldnt you just cut it in ?
Re: Body Kit fitted
v6 steve wrote:couldnt you just cut it in ?
Eh?
Rad is breached, needs a recore
Managed to get the rad out, also removed the a/c rad as surplus to requirements as a/c is disconnected
