Opel Calibra Last Edition Nr.0462 * 400+ hp
Re: Opel Calibra Last Edition Nr.0462 * now with Turbo
by D-Man » Tue Sep 10, 2013 4:14 pm
Long time this thread was not updated.
During this time following works completed:
- refurbish F28 - ✔
- install Sachs Performance clutch - ✔
- install 300lph Bosch pump - ✔
- install Bosch 440cc injectors (Green Giants) - ✔
- install 5 bolt hubs - ✔
- install Calibra turbo fanblades + Fulda Carat Exelero R16 - ✔
- install new front speakers - Hertz DSK165.3 - ✔
- reduce noisiness of front doors - ✔
by EddeyDancer » Wed Sep 11, 2013 6:55 am
Is very good... :clap:
by D-Man » Wed Sep 11, 2013 7:54 pm
Thanks, Eddey! :)
by rich30mex » Wed Sep 11, 2013 9:10 pm
Good work pal
by D-Man » Wed Oct 02, 2013 12:42 pm
Today is a good day :)
I've finally found correct front caliper carriers from SAAB in a local junk yard for a bragain in order to upgrade front brakes to 308mm :dance:
by v6 steve » Wed Oct 02, 2013 5:54 pm
when i got mine i bought Zafira disc's they worked out cheaper
by SAMARAI » Wed Oct 02, 2013 6:46 pm
D-Man wrote:Image
Great work man!
One thing that stuck out to me was your rear boot lip. Where did you get that from? I've been really keen to try and get something just like that on mine. Did you get it ready made for the calibra or cut it down from a universal one?
by D-Man » Wed Oct 02, 2013 7:58 pm
v6 steve wrote:when i got mine i bought Zafira disc's they worked out cheaper
Discs are identical. But what about Zafira calipers/carriers? As far as I aware they won't fit to Calibra... :roll:
SAMARAI wrote:Great work man!
Thanks :) I got it from the German eBay. But IIRC this was the seller.
No cutting work involved, just paining. It came with adhesive tape on the bottom.
by v6 steve » Wed Oct 02, 2013 9:00 pm
the disc's are the same you cant use the callipers just use v6 or turbo ones with your sabb carriers and 308mm discs
by D-Man » Thu Oct 03, 2013 7:22 am
v6 steve wrote:the disc's are the same you cant use the callipers just use v6 or turbo ones with your sabb carriers and 308mm discs
Now I catch you :)
Thanks for the advise, mate.
I am thinking about ATE PowerDisc + EBC Greenstuff to the front...
by D-Man » Fri Oct 11, 2013 2:50 pm
:dance:
by D-Man » Thu Apr 10, 2014 9:47 pm
Spring is here, Calibra is being prepared for the new season.
Besides a/m brake discs I got EBC YellowStuff for front, HEL Performace brake lines and CL Racing brake fluid
Calipers are going to be refurbished and powdercoated black before installation.
Another bonus for Calibra - I finally bought a head unit I was planning to get - Becker Indianapolis Pro.
With its kinda retro design it has plethora of quite modern features like mp3, navi, bluetooth :dance:
More things to come :)
by D-Man » Wed May 14, 2014 9:37 pm
1000cc x4 8)
F&%k the fuel economy! :lol:
by D-Man » Mon Jun 02, 2014 1:21 pm
Couple of spy photos from the current process:
Under the bonnet
308mm ATE PowerDisc + EBC Yellow pads
I hope we'll bring the car back to roards still in this week.
Once Calibra will be started I will post a list with recent updates, as not everything can be seen on pictures 8)
by D-Man » Mon Jun 09, 2014 2:30 pm
Well, big job done!
Now specs look as follows:
Engine:
exC20XE with girdle
Head Coscast (late type)
Turbocharger T3/T04E 0.63 1.4bar/20psi@4300rpm
Wastegate 38mm
Pistons JE Pistons CR 8.5
Oil squirters for piston cooling
Rods - H-type, ARP bolts
Oil 10W-60
Oil pump Z20LET
Injectors - Injector Dynamics 1000cc
Fuel pump Bosch "044" 300lph
Spark plugs - platin Bosch F5DPOR
Separate ignition coil from BMW
Cams - dBilas Dynamics 276/276, 10.5, vernier pulleys
ECU - MegaSquirt2 v3
Oxygen sensor wideband Innovate LC-1
Custom stainless steel inlet manifold with enlarged throttle
BlowOff - Bailey DV26
Oil catch tank
Exhaust 70mm stainless steel + screamer pipe
Transmission:
F28, refurbished, new 1st and 2nd gear synchros
Locked transfer box with reinforcement plate
Clutch - Tripple disc Quatermaster from NASCAR world
Brakes:
Front 308mm ATE PowerDisc + EBC YellowStaff pads
Rear 270mm standard
HEL Performance braided hoses
CL DOT4 Racing bake fluid
Calipers refurbished and powdercoated in matt black
Suspension:
Shocks Koni
Springs Eibach Pro-Kit
According to my tuner, engine now has been mapped to 430bhp @ 6500rpm / 470nm @ 5600rpm
Turbo reaches positive pressure @2700rpm, ~0.3b/5psi@3000rpm, full boost ~1.4bar/20psi@4300rpm
Revlimiter set to 6500rpm.
Injectors' duty cycle around 50% at full boost.
I am quite happy :)
The only thing that is driving me crazy now - tripple disc clutch while driving in a traffic :roll:
