Eddey's V6 - The Ghost...
Re: Eddey's V6 - The Ghost...
vec 160 wrote:I'm sure it sail through... With all the effort that you've put in, there can't be much wrong with it... Alan
Thanks Alan... The Ghost 'Passed' the MOT Inspection with out any dramas...
The MOT Inspector said: 'Every year the cars I check, get noticeably worse in their condition,
but this car seems to be looking better, as each year passes by!' He's right about that...
Well done, another year of motoring in the bag
- Gold Member
craigyboy wrote:Did you have any luck with that steering rack mate?
No Action taken as yet... It's not that Urgent... Still considering my options...
Happy 2014... Best Wishes to All...
craigyboy wrote:All the best Eddey
Thanks Mate...
After a fairly lazy 2013, it's time to get on with things for 2014
Now from memory, here's My Check-Off List...
INTERIOR:
Upgrade the Headset Stereo - Done
LED Upgrade bulbs for the dash display - Done
Fit the chrome dash dial surrounds -Done
Swap the front seats around
REAR:
Rear Wheel-arches to be rolled (perhaps)
Fitting of NEW Rear Shocks and Springs - Done
FRONT:
Passenger side inner drive shaft boot
New front shocks and bump stop kit
New top strut mounts and bearings
New front Brake Pads
Replace Head Light Bulbs
ENGINE:
Replace the Air-Con Condenser
Re-gas the Air-Con System
Replace Thermostat Waterpipe
Recondition of the Steering Rack
Quite a dense list my friend but for the cars we always have a, soft spot for.. Money and time well spent!
Sent from my LT15i using Tapatalk
PROGRESS UPDATE... In addition to my 'To Do' list...
The Battery finally died, so I fitted a Brand NEW 600CCA Battery...
Also I finally replaced the Original Tape Deck, with a SONY CD Headunit...
This Unit also has the Bluetooth feature, so I can now take calls, whilst driving...
PROGRESS UPDATE...
I'm really happy with my 'NEW' SONY Stereo Head-unit...
The sound comes through really clear, and that's with the Standard speakers...
I finally purchased some NEW Rear Shocks, and will make a start on that within the next 7 years...
http://www.ebay.com.au/itm/271018406238 ... 1439.l2649
My Rear Springs are from K-Mac at Rockdale on recommendation of Boris BMJ (Green V6) Cost $260
The 2 x KYB White Rear Shocks cost $240 Posted... So that's $500 spent, just on the Rear Suspension...
I'm keen to see how they will go, and how the ride will be, with the New Shocks and Springs fitted...
This will be interesting...
Code 16
EddeyDancer wrote: I recently got a 'Code 16 - Knock Sensor' that comes and goes...
CODE 16
A year later and it still comes on, but goes off once the car has warmed up... Weird!!!
Perhaps time to replace the Knock Sensor, but is it the front or back one?
Code 16 is the front bank 2,4,6
Here is a link to fault codes that might be useful http://homepage.ntlworld.com/hoglabs/do ... _fault.htm
HTH
Alan
HTH
Alan
- Gold Member
vec 160 wrote:Code 16 is the front bank 2,4,6
AWESOME... Thanks heaps for that...
