Snowflake
Re: Snowflake
What i'lol do is let the car get fully up to temperature the try again
Terry
Terry
Re: Snowflake
Ok so I took the other half to Asda while she went in I stayed and let the car get up to temperature, once it was upto about 91'c I lifted the bonnet and the top rad hose looked fit to burst it was solid, I carefully unscrewed the header cap i think there was a bubble but not 100% as that was the only slight sign, but after getting the other half to apply some revs there was nothing no little or big bubbles, and the pressurised hose was now squeezable.
http://youtu.be/HS8IFA0LD6Y
Terry
Terry
Re: Snowflake
Both rad hoses are hot, and the radiator, it is hot but to be really picky it prob not as hot at the very bottom but nothing like the old one was, the old radiator had a huge difference
Terry
Terry
Re: Snowflake
Do you still think it could be the head or has anyone else got any ideas? Just to throw it out there? May light up a bulb in some else's head too?
Terry
Terry
Re: Snowflake
What would I need to look for if I decided to take the head off?
Do you still not think it could be thermostat related?
If I was to take the head off I'd prob wait a while get some money together get my self a new timing kit, water pump, and head gasket kit and do it all at once, just having to put up with the problem for a while. How much do heads go for these days? If it's warped or cracked, cheap enough try and pick one up just I case I come across something when changing everything.
Terry
Terry
Re: Snowflake
Sorry only just noticed you had replied, no we didnt end up doing it, as rich was certain it wouldnt be so told me not to buy one but we bought the rocker cover gasket instead! Which i believe has done the trick of stopping some oil
Terry
Terry
Re: Snowflake
Ok so last night I took the daughter back to her mums which is a 16mile round trip, knowing the header tank was full, I then come to drive it this morning thought I better check and the header tank was bone dry?
Terry
Terry
Re: Snowflake
Surely not that much 1.5litres it took to fill back up
Terry
Terry
Re: Snowflake
Tkeenan2107 wrote:Surely not that much 1.5litres it took to fill back up
If got a leak on the van mate and it's exactly the same whe parked it's a drip but took it to Barnsley around tripoff about 25 miles and had to fill it up on the way back like I saide you need to sort the leak first
Re: Snowflake
It leaks when engine is off or cool and I squeeze on the hose but when engine is up to temp and hoses are pressurised it doesn't which is weird
Terry
Terry
Re: Snowflake
Tkeenan2107 wrote:It leaks when engine is off or cool and I squeeze on the hose but when engine is up to temp and hoses are pressurised it doesn't which is weird
when hot the pipe will expand which might be enough to stop it for a short time
Re: Snowflake
Ok so 2nd day in the new job goes to the car this morning thought I better check again, and yes you guessed it no water in the header took nearly 2 litres to fill, filled it up drove 8 miles to place of work had a good day comes out and thought I better check just in case and you guessed it again no water, topped it up again but I also spotted this on the top of the engine???mhas something blown?
When I got home I left the car running and flipped the bonnet up and the hoses were the most pressurised iv seen and felt up to date I struggled to squeeze it at all.
Terry
Terry
Re: Snowflake
Just going to throw this out there......Have you checked the rubber seal in the header tank cap is ok?
They can sometimes twist and leak under pressure, the leaked water from there you'd never find.
Re: Snowflake
Yes Andy rich checked it, and in the pics you will see all that white stuff it wasn't there this morning or before
Terry
Terry
Re: Snowflake
Well nothing seems to be going right, gone for a little run this morning and exhaust has snapped looks like someone has previously tried bodging it up but not done well, held by a little piece of metal on the top! Which section is this? Or anyone with a nice twin exhaust and this section for sale?
Terry
Terry
