drivers side headlight
Need ideas, noticed my drivers side headlight was out, thought it was the HID kit I'd fitted over christmas so swapped back to standard bulbs. still no go.. so swapped with the passengers side bulb which was working and it still didn't light up. All 4 bulbs I've tried do not work on the drivers side but will in the passenger side. Any advice please?
Re: drivers side headlight
have you checked the fuse ?
You need a test lamp or multimeter and check that you have voltage (which we can all guess you don't) and then trace it back from there...
