Brake system dashboard warning light.
by Pinner-man » Fri Sep 02, 2022 9:24 pm
Hi
My brake system dashboard warning light has come on. However the ABS light is OFF. I have checked the brake fluid reservoir - normal level, checked the brake pad pressure pistons - no sign of any leaks and the brakes work normally. Any suggestions of what could be the trouble.
I have a picture / video of the light but I do not know how to attach it to the post.
Regards
Pinner-man
Re: Brake system dashboard warning light.
by Pinner-man » Sat Sep 03, 2022 5:32 pm
HI
Problem solved. The warning light referred to a brake light failing, not a brake system failure - Changed the bulb - warning light went off.
Regards
Users browsing this forum: Bing [Bot] and 25 guests
