Funny goings on
How do I drop the boost?
Last Wed dropped the kids at school and starting up again the alternator light was on.
No problems at all running, the faster I went the dimmer the light got, the more elecs I turned on the brighter it got.
BUT started fine every time and volt gauge in car showing healthy 14 volts always
Yesterday morning got in started up, the light's not on any more (apart from ignition on but not started as it should be)
Anybody any ideas?
Anybody any ideas?
DBV6
When the light glows very bright its generally a new alternater required as dan says. the reason its not on any more is generally the bulb itself blows due to too much current coming through. The alternater has a regulater inside which is generaly the bit that goes get a garage to check the voltage/amperage that you are charging at and dont rely on the internal voltmeter
Tim2001
Users browsing this forum: No registered users and 213 guests
