Bulb failure warning light.
Hi All
When drving with lights on a warning light on dash is illuminated.
Checked in the hand book and it's the bulb failure warning light (the one without the brackets). But when I check my headlights, sidelights and taillights they are all working. So why have I got the warning light?
Any thoughts!!
Any thoughts!!
Jas
Hi i had a similar problem with my rear lights everthing seemed fine.In the end it was the bulbs i got someone to sit on the brake peddle and form inside the boot tapped the back of the brake bulb and this kept cutting out the only way i found of stopping this was to replace both bulbs and this cured my problem.Hope this helps:?:
benjamin298
carl_freeman
