Fitted new head unit
Factory immobs
by Mac » Tue Dec 21, 2004 4:16 pm
Put a new head unit in car and is it normal it will only work when the ignition is on?
Also when the cars running and your playin' tunes, When you switch off the car the sterio goes off as well, Then if you restart the car the sterio starts up again from where it left off.
Never been able to do this with all my other Vauxhalls, So I am curious what I've done different this time?
Mac
by Smurf » Tue Dec 21, 2004 4:53 pm
All down to the wiring from the ISO plugs - in most cases you can move the wires so you have a perm live feed to it, rather than switched.
Smurf
RE: Fitted new head unit
by SukySaggi » Tue Dec 21, 2004 4:54 pm
Everything seems fine. My CD player does exactly the same thing.
SukySaggi
Re: RE: For Sale - Custom Cally Bonnet
by Robert_Dale » Tue Dec 21, 2004 5:15 pm
mate there are 2 wires
red is ignition only
Yellow is CONSTANT live, you will need to feed the Yello wire to the live wire on your stereo mate
HTH rob
Robert_Dale
RE: Regional Register
by cally228 » Thu Dec 23, 2004 6:50 pm
Swap the yellow and Red wires over mate, should sort it
RE: alarming questions.....
by Enigmatic » Fri Jan 07, 2005 5:20 am
yeah had the same problem with mine just to add
bassjunkies sold me an iso adapter that i didnt need
but they did sort it out by swapping the red to yellow etc
but....... i installed the OE stereo and you can turn this on without ignition being on
what have i done wrong?
Enigmatic
by trev150 » Fri Jan 07, 2005 11:51 am
Yeah mine works the same.
Trev
RE: speedo Rings
by c1emm » Mon Jan 17, 2005 7:19 pm
mines the same
ignition on = cd player & Amp on
c1emm
RE: ABS Light
by projectx » Mon Jan 17, 2005 10:52 pm
I deliberately re-wire every stereo/plug I get so both stereo feeds are fed from the perm live so I can have the stereo on without keys in the ignition. Something you might wanna consider while you're in there re-wiring it....
Though you do have to remember to turn it off when you get out, otherwise it'll kill your battery [img]/smile.gif[/img]
projectx
