Oil pressure sensor...Nightmare.!!!
by gremlin » Fri Jan 28, 2005 11:51 am
My oil pressure sensor is of the scale.!!
As soon as i turn my ignition on my oil pressure sensor gauge fly’s of the top of the scale as far as it can go. I’m sure its not the real pressure of the engine as that isn’t even running and can only think it is a short somewhere.
Would it be a duff sensor or a short somewhere?
Where would i find the sensor so i can trace the wiring backwards?
gremlin
RE: Steering wobble when accelerating
by craigmcd82 » Fri Jan 28, 2005 7:06 pm
Very unlikely to be a duff sensor OR a short.
It will probably be a broken connection on the sensor - This happened to mine.
I got it sorted when I changed the oil as I could unscrew the sensor without oil pi$$ing out.
Its fiddly but you might be able to leave it on and reconnect the wire if you take the O/S wheel off & Jack it up.
The sensor is behind the oil filter. Its a small cylindrical shape, with 2 or in your case probably 1 wire(s) coming from it. I *think* the one your after is green/grey!
HTH!
craigmcd82
by sofaman » Sat Jan 29, 2005 1:14 am
Find the connector and pull the wire off. If the reading is still off the scale then u have a short in your wiring. If it stays at 0 then it's probably your sensor.
HTH
sofaman
RE: Slow for super cars
by Paul » Sat Jan 29, 2005 10:12 am
I've had this trouble on both my Calibra's.
Both time it was cured by cleaning up the connector, which gets very corroded. (It's just an unprotected female spade crimp)
Paul
by Fragger63 » Sun Jul 03, 2005 7:05 pm
Hi I have the same problem with the oil guage shooting off the clock as soon as i turn the key where is the sensor located on a 97 Ecotec 16v Calibra ?????
Fragger63
by haroldhettaturbo » Sun Jul 03, 2005 7:48 pm
hi m8
i have similiar probs with mine, my gauge reads fine but the red oil light flickers on.
Gunna try a new sensor
Hh
haroldhettaturbo
by tsdinos » Sun Jul 03, 2005 10:55 pm
I'm in the club with the buggered sensors too! as mine oil pressure gauge do the same, although sometimes (rarely) when i turn the engine it seems to indicate but when the engine starts always goes to the far end and stays there
tsdinos
by Johnnytenpints » Mon Jul 04, 2005 12:19 am
<!--QuoteBegin-haroldhettaturbo+--><div class='quotetop'>(haroldhettaturbo)</div><div class='quotemain'><!--QuoteEBegin-->i have similiar probs with mine, my gauge reads fine but the red oil light flickers on.<!--QuoteEnd--></div><!--QuoteEEnd-->
I'd be a little concerned if the oil light is coming on. Apart from checking there's oil in the engine, I'm sure someone more knowlegable on here will give a better idea what the problem is.
Johnnytenpints
by Chavtastic » Mon Jul 04, 2005 5:53 am
<!--QuoteBegin-haroldhettaturbo+--><div class='quotetop'>(haroldhettaturbo)</div><div class='quotemain'><!--QuoteEBegin-->hi m8
Hh<!--QuoteEnd--></div><!--QuoteEEnd-->
Have you got enough oil in it? :oops:
by haroldhettaturbo » Mon Jul 04, 2005 3:41 pm
lol yes
haroldhettaturbo
by se6 » Mon Jul 04, 2005 8:53 pm
My gauge goes straight round to the max also. I guess putting the sender on may be a good start in fixing this though! Maybe when the weather improves i will get round to it.
