batterys
batterys
hi guys, had to get a jump start today the battery had gone, it was my own fault as i left the interior light on:oops: . anyway my question is what amp/hours are the turbo/v6 batterys, the one i have on now is a 55 a/h batt, can i /would it benifit me to put an uprated battery on baring in mind that i intend to install an amp/sub plus a uprated alarm system
chief
so what you are saying fraz is that if i upgrade to a turbo battery i also need the alternator as well?. at the moment going by the voltage gauge it reads 14-14.5v when the engine is running, 12 when its not, when it wouldn't start it read around 10/11 volts, i'd say this means the alternator is fine at the moment, but i'd just run the battery down. it will probabley be o.k. but i'm worryed about fitting the ice alarms etc any suggestions.:confused:
chief
I've got the biggest battery I could fit in my V6 - it's one of the Vauxhall GO batteries - and with the trade club discount they're pretty reasonable.
I also have a 100A alternator at the moment and it's coping fine. I have a spare 120A unit in the garage just in case I need it [img]/biggrin.gif[/img]
I'll find out the rating of the battery for you...
Smurf
There appears to be some confusion over the batteries role in this thread.
The battery is only there to store an electrical charge big enough to start the car, and provide support for the alternator when current draw exceeds the alternators output.
When the engine is running, the electrics should run off the alternator.
Upgrading to a higher amp battery will help but ultimately you'd be better off looking at doing both the alternator and the battery.
I used to own this Calibra...
I now own this one.
Xbox live gamertag IcedSage
I now own this one.
What is a cost of an alternator as I think mine went today. Set off from work lights on but noticed the dasboard lights were very dimm. Then about 200 yards up the road the red battery light came on the dashboard. I also seem to hear a whrrring type noise at low revs? Dont know if this is normal as I normaly have my stereo on so dont hear what the engine sounds like.
With no lights on and driving the volt meter read 13 the one next to tweleve I am pressuming it goes up in 1's?
Then when I put headlights on, stereo, heating, rear heated windscreen, heated seats etc it dropped to just below 11.
Didnt seem any different to drive though. So would this be an alternator? plus how much do they cost?
colic
Ok <!--quoteo--><div class='quotetop'></div><div class='quotemain'><!--quotec-->any ideas on where to get a 120A alternator guys? mine is 100A dead for the second time in 6 months<!--QuoteEnd--></div><!--QuoteEEnd-->
I got mine from vauxhall about £120. for the 120 amp one.
Its not cheap but works ok on mine and all the
I have in mine i need it. [img]/smile.gif[/img]
