I need a definitive answer please....
by diamondcali » Fri Feb 18, 2005 8:22 pm
<!--fonto:Arial--><span style="font-family:Arial"><!--/fonto--><!--sizeo:2--><span style="font-size:10pt;line-height:100%"><!--/sizeo-->Ok guys,
I know this has been covered a million times but....
Will 18x8 rims fit on my cali or not???
My car is lowered by 35-40mm.
Will the 8" cause me problems or do I have to go with 7.5".
Your help will be much appreciated.
Andy.
<!--sizec--></span><!--/sizec--><!--fontc--></span><!--/fontc-->
diamondcali
by davefly76 » Fri Feb 18, 2005 8:35 pm
what offset? this will cause more problems than the width
[img]/smile.gif[/img]
davefly76
by diamondcali » Fri Feb 18, 2005 8:41 pm
The offset is 40,
any good????
diamondcali
by projectx » Fri Feb 18, 2005 9:04 pm
I would be surprised if you don't get some scuff on the top of the front arches when going over bumps, and perhaps a little bit on the insides when on full lock, but other than that, I don't think it'll be too bad. I've got 8x17's (I think they're a 40 offset) with 215 40 tyres, and that's the only times I get scuffing.
projectx
by Mark1 » Sat Feb 19, 2005 12:30 am
Mine are 8x18 and I think the offset is et47. Have a word with V6_E as I know he has just changed his.
by diamondcali » Sat Feb 19, 2005 12:37 am
Hi Mark,
<!--quoteo--><div class='quotetop'></div><div class='quotemain'><!--quotec-->Mine are 8x18 and I think the offset is et47.<!--QuoteEnd--></div><!--QuoteEEnd-->
And do you have any problems please???
Andy.
diamondcali
by Mark1 » Sat Feb 19, 2005 12:43 am
Andy the only prob I've had is the N/S/F rubs now and then, when braking and turning in but not sure why.
Check with splinter and V6_E as we all have the same size/make of wheels.
by diamondcali » Sat Feb 19, 2005 1:50 am
Cheers Mark.
diamondcali
