reverse switch
reverse switch
by Gandalf » Fri Feb 11, 2005 7:31 pm
Got one of these and fitted it - no difference discovered the reverse lights were missing (or at least one was) replaced with one i got at the scrappy, still nothing.
I think i'll get my mates live tester to see if they're getting power before i buy a new set of bulbs.
Any other suggestions appreciated!
cheers
Mike
Gandalf
by STEVEN MAYHEW » Sat Feb 19, 2005 11:58 pm
Bridge out the reverse light switch plug with a piece of wire and that will test the whole light circuit (So long as the fuse is ok) That will tell you whether or not it was just bulbs or the switches you have are knackered
STEVEN MAYHEW
by splinter » Sun Feb 20, 2005 12:01 am
Ok mine is going off and on sometimes, So where is the switch ??
Thanks Ian.
by STEVEN MAYHEW » Sun Feb 20, 2005 12:26 am
If you look at the battery, look slightly left and then down you will see the clutch release arm on top of the gearbox. Hidden underneath you will see a little two pin connector plug. This is the reverse switch. The switch is definately the prob with yours - common fault
STEVEN MAYHEW
