Help Me!!!!!
Help Me!!!!!
can anyone please,please help me????????
it all started when i decided to change all my control switches to 'blue'l e d style-i have been buying the switches from ebay with no problems,until now-i replaced the rear heated window swicth with a'blue'one......and nothing happened!so i put my origanal one back in-that doesn't work now either??????i have checked the fuse in the fuse box(under dash)but all fuses are ok.i have tried numerous switches since and nothing-WHATS WRONG?????also having been speaking to loads of people about this i find out that my heater control display is supposed to light up!!!but mine doesn't!!also i find out that i should have more lights on the dash display when i turn the key(bulb check for example)
my calibra is a 1993/4 se-origanaly an 8v,is there a differance in elctronic display speck(apart from digital clock+air con+extra fog switches)?
<!--sizeo:6--><span style="font-size:24pt;line-height:100%"><!--/sizeo-->[/size]
[size=6]help me please!!!!!!<!--sizec--></span><!--/sizec-->
PAULJOHNSON
guess what???????i sorted it!the problem was.....when i replaced the switches,i must of puched the 'new'switch in to hard and pushed the 'wiring; plugs back!so the switch wasn't making a complete connection-after getting realy anoyed with this not working properly,i stripped the dash...and there it was staring me in the face-what a plank!!!thanks for you help tyhough!
PAULJOHNSON
