Things can only get better
After replacing the rear calipres, brakes were bled as as they were still a bit spongey re-bled all the brakes again today and still they are sponge like. There is also a popping sound every so often from the rear passenger side when pressing the pedal. Dont know what that is. I do get pressure to the pedal if it is pressed once before using properly.
Think i'm going to replace the master cylinder and hope this sorts it out. B*gger Calibras
Re: Things can only get better
I would try a pressure bleeder first, you can get those that use the tyre pressure they work quite well
i had this with the frontera no matter how what way we did it, it was the master cylinder but as fraz said try a pressure bleeder we have one and i was amazed how good/easer it is with it
Will use the tyres on the boys SE9 . Hes not using it
well rob if you do need a new mastercylinder i have one here aswell as a servo from when mine was a redtop
tazz666
Is there anything you dont have , i will bear that in mind thanks
Robs-se wrote:Is there anything you dont have , i will bear that in mind thanks
yes loads mate i need to get some more doners in to replenish my stock,lol
tazz666
tazz666 wrote:yes loads mate i need to get some more doners in to replenish my stock,lol
but its gotta be Blue
vinny_69
vinny_69 wrote:tazz666 wrote:yes loads mate i need to get some more doners in to replenish my stock,lol
would quite like a black one this time
tazz666
tazz666 wrote:well rob if you do need a new mastercylinder i have one here aswell as a servo from when mine was a redtop
Hi Tazz, i would like to take you up on your kind offer please
pleasure mate i know vinny is coming up here on the 16th of october or do you want it sooner mate
tazz666
tazz666 wrote:pleasure mate i know vinny is coming up here on the 16th of october or do you want it sooner mate
Soon as, i'm rather tied up in October. Name a date and time thats ok for you and i will come up ( i can do this week anytime)
well rob anytime mate when ever it suits you mate i will pm you my address
tazz666
OK cheers, wot about Wednesday afternoon?
Users browsing this forum: Google [Bot] and 35 guests
