code 19 on v6
code 19 on v6
guys
callyman kindly did my sparkplugs today at his place and we took it for a spin to see if theres a difference in the power and we hit 4500 revs in 2nd gear and the ecu flashed on and the engine stuttered between 2nd and 3rd gear .so we got it back and did the paperclip test and it said it was 'code error 19' crank sensor but how much can i get these for and are they easy could i fit it?
Re: code 19 on v6
just under oil filter....try cleaning end if its covered in crap when you remove.(front of engine if your not familiar with oil filter)
k1nty
Re: code 19 on v6
I checked the connector after it happened, and all looked fine.
I think the sensor might be shot or dirty etc
When accelerating gently all seems fine, but when you boot it it's holding back, almost feels like a misfire
Re: code 19 on v6
callyman wrote:I checked the connector after it happened, and all looked fine.
does the traction control work ok...try it the traction control off.
k1nty
Re: code 19 on v6
im almost certain it does sound like the crankshaft sensor as it said on the paperclip test guys, it hit past 4500 revs and you can feel a slight lack in power and if you leave it a little longer the ecu flashed on and off and then you change to 3rd and you have a job getting upto say 80 ish on the fast roads eg motorways etc .no misfire when idling or reving engine only as andy said when you boot it is lacking .
on a personal note ive had this car over 2 years now and have only ever had to replace one of the knock sensors and two fuel leaks so maybe andy is right and its the sensor on its way out.
Re: code 19 on v6
get new sensor, replace old sensor with new one, try car and report back .......simples
Re: code 19 on v6
yep agreed lol
Re: code 19 on v6
either this will still be page one or we're on page two
EDIT - damn still page one
Re: code 19 on v6
One page will do thank you.
Re: code 19 on v6
Fraz wrote:get new sensor, replace old sensor with new one, try car and report back .......simples
You should know Baz by now nothing is ever simple
You think he's bad on here you should try living with him all ive heard since yesterday is crank sensor this crank sensor that
T1N4
Re: code 19 on v6
hey cmon guys , i can take loads from you lol
anyway i rang autovaux and they had last one of the shelf for £50 inc vat + delievery (didnt realise it was this expensive ) so thats been ordered now but i have been reading up about the crankshaft sensor and i was under the impression that it does several jobs ie one starts the car and another one with like the symptoms i was having
extract from alan knight"topbuzz":
1)
A Crankshaft Sensor (also known as a Crankshaft Angle Sensor - or CAS for short) watch's the position of the camshaft and its relationship with the piston position inside the engine. The CAS is an inductive signal generator, it measure reluctance. The CAS is typicality found on injection engines, and its an important sensor. Without it, the engine will not run at its optimum, and if faulty, the ECU warning light shall illuminate on the dash.
2)
How do I know if a CAS has malfunctioned?
As previously explained, the CAS is vital for the performance of the engine. It supplies a signal back to the ECU so it can calculate ignition timing and the correct fuelling. If the CAS is sending back incorrect data, the performance of the engine decreases significantly, even stop it from working.
However, to overcome this problem, the EMU can use a data map within its memory (which was set by the manufactures) which use some default values to regain correct fuelling and ignition.
But because this data is static and not true live data coming from a CAS, the performance isn't at its optimum. What this means is that the car may feel sluggish, but the car will still work. Also the ECU warning light will be illuminated on dash.
and this is what i had experieneced number 2
is this correct and is it located on the bottom of the block (the sensor)
1)
2)
Re: code 19 on v6
ok thanks , all i know is it came up with code 19 (which ive looked on v6calibra.net and suggests its crankshaft sensor so it must be right. and as the car is running perfect with no problems revving and idleing.
Its running just as it always has , sweet lol .at first i looked and realised i was lokking at knock sensor which is just underneath the water hose to the left so i guess it would only be accessible via jacking the car up and below the exhaust manifold cover .
