fans/fuse box
fans/fuse box
hay,
the blowers on my calli are not working, thought it could have just been a fuse as i dont get anyking of noises from the motor and the motor itself looks ok.
after a bit of research i find the fuse numbers 4 and 24 are the ones im looking for, however there are no terminals in those slots to fit a fuse ... there empty ... ALSO i seen that number 19 is for the 4x4, i know vaux will no doubt use the same fuse box fot the 4x4 but there is actualy a fuse in 19, and i found that a little strange, dont know if anyone can shed any light on that? the car is a 2.0 ecotech 16v
cheers
cheers
scott_j_g
Re: fans/fuse box
vinny_69 wrote:have you changed the switch in the heater console?
i have not ... and have no idea where or how... where do i find this?
scott_j_g
