Handbrake
Handbrake
Looks like i've popped a pin on the handbrake, so the discs are comming off to check/reseat. Only thing is i cant remember the way the adjuster wheels go once the hub is back on. Is it the drivers side the wheel gets flicked up and over and the passenger side down and under or the other way round
Re: Handbrake
i cant for the life of me remember mate, i think the way you said was correct but there is only one way to find out
Re: Handbrake
Well i got the discs off with some effort, calipre bolts on good and proper, the shoes are as they should but only the drivers side was working as it should. Passenger side was only just touching the disc when handbrake was applied. Turns out the adjuster has completly seized. So off to good old Vaux for replacement. Now have to wait until Friday to pick them up
Re: Handbrake
the passenger side you flick down and driver side you flick up i put new discs n pads on my cally the day
john.ness
Re: Handbrake
Thanks for that mate, save me sometime as i always end up going the wrong way and then having to dismantle and starting again
