Steering rack
Steering rack
by Robs-se » Mon Jan 27, 2014 4:05 pm
Is it possible to get to the drivers side mounting bolts by just taking off the wheel. I want to see if the bolts are loose or the rack is knacked before actually taking the servo and header tank and other bits off unnecessarily
Re: Steering rack
by Robs-se » Tue Jan 28, 2014 12:26 am
i suspect the rack is loose in some way as i can grab hold of the tie rods where they meet in the middle of the rack and waggle it up and down where as on the old astra i had you couldnt move it at all like that. I'm hoping the rack has failed or come loose and not rusted away from the bulk head
Re: Steering rack
by Fraz » Tue Jan 28, 2014 12:37 am
is the lock tab still on the bolts ?? if not they may well have worked lose ...15mm
Re: Steering rack
by Robs-se » Tue Jan 28, 2014 4:16 am
yep that's still there, when giving the tie rods a waggle its the whole rack that moves
Re: Steering rack
by Robs-se » Tue Jan 28, 2014 3:21 pm
Passenger side is solid so need to check drivers side and hopefully its not the mount on the bulk head rusted away
Users browsing this forum: Google [Bot] and 27 guests
