winter projects ?
Re: winter projects ?
Allys Cally wrote:v6 steve wrote:need i say any more
i think we came to the conclusion that that was your fault![]()
for letting me drive it in the first place
thats why i should get a shot before you
I'm completely stripping the under neath of the cally and under sealing it, then pollybushing and painting everything. Also having my alloys re-fubished/ powder coated.
Making a double din centre console for the Astra coupe and putting a sound system in.
Head to put on my L plate turbo, C20let let &box to put into the turbo, that i'll be selling and attempting to put together the car I'm buying from Aldo!
no calibra at the moment
but
skyline r33
grind any surface rust off the underside and underseal properly
fit spec 2 interior
fit pillar mount gauges
re-spray inner wings
fix leaky boot seals
replace rear screen as the de-mist not work
fit tein coilovers
vectra cdti 150
replace F****d turbo (skyline as a daily is getting expensive)
re-map or dtuk box
paint front bumper and drivers wing
replace foglight and surround
but
skyline r33
fit spec 2 interior
fit tein coilovers
vectra cdti 150
re-map or dtuk box
I've just done a full ice install on my Type-R which will see me through the winter
I'm currently looking for a 911 Turbo or a Ferrari 355
Plan to take it off the road and replace all suspension bushes in the rear and replace bearings and hubs at the front ready for mot in feb.
Hopefully will get the Vectra VXR so i can do the above without rushing it to get it back on the road as its my everyday car at the moment.
- total refurbishment of F28 + Sachs Performance clutch installation
- new fuel pump install with better capacity (+maybe swirl pot)
- paintwork after a couple of unpleasant road accidents
- some minor works
- some minor works
Robs-se wrote:Plan to take it off the road and replace all suspension bushes in the rear and replace bearings and hubs at the front ready for mot in feb.
I have a Vectra SRI and i know its not the same but i have had to change the 4 springs. At the first MOT i got an advisory for slight play in the front wheel bearings, i changed them 2 weeks before the 2nd MOT and i got an advisory for slight play in the front wheel bearings
It may be worth giving them a look over mate. Oh and the cd player is s**t, you could go over a fag paper and the cd will skip.
Redo the other wheel arch. Did one with a 3 stage treatment from america last year, and one without for comparison. The treatment side has held up fine, while the other has not. It seems grinding both sides of the arch, etch, clean and epoxy seal can stop the rot.
12" Alpine Type R sub in the back now that the alternator is upgraded.
James_Mould wrote:I'm completely stripping the under neath of the cally and under sealing it,
did that in the summer, took two months to dry out properly.
