winter projects ?
Re: winter projects ?
by v6 steve » Sun Dec 09, 2012 7:29 pm
Allys Cally wrote:
v6 steve wrote:need i say any more :think:
i think we came to the conclusion that that was your fault :roll:
for letting me drive it in the first place :lol:
thats why i should get a shot before you :snooty:
by James_Mould » Sun Dec 09, 2012 8:52 pm
I'm completely stripping the under neath of the cally and under sealing it, then pollybushing and painting everything. Also having my alloys re-fubished/ powder coated.
Making a double din centre console for the Astra coupe and putting a sound system in.
by KERR_SE9 » Sun Dec 09, 2012 9:58 pm
Head to put on my L plate turbo, C20let let &box to put into the turbo, that i'll be selling and attempting to put together the car I'm buying from Aldo!
by matty0785 » Sun Dec 09, 2012 11:15 pm
no calibra at the moment
but
skyline r33
grind any surface rust off the underside and underseal properly
fit spec 2 interior
fit pillar mount gauges
re-spray inner wings
fix leaky boot seals
replace rear screen as the de-mist not work
fit tein coilovers
vectra cdti 150
replace F****d turbo (skyline as a daily is getting expensive)
re-map or dtuk box
paint front bumper and drivers wing
replace foglight and surround
by Chavtastic » Mon Dec 10, 2012 5:01 pm
I've just done a full ice install on my Type-R which will see me through the winter
I'm currently looking for a 911 Turbo or a Ferrari 355
by Robs-se » Tue Dec 11, 2012 9:35 am
Plan to take it off the road and replace all suspension bushes in the rear and replace bearings and hubs at the front ready for mot in feb.
Hopefully will get the Vectra VXR so i can do the above without rushing it to get it back on the road as its my everyday car at the moment.
by D-Man » Tue Dec 11, 2012 10:40 am
- total refurbishment of F28 + Sachs Performance clutch installation
- new fuel pump install with better capacity (+maybe swirl pot)
- paintwork after a couple of unpleasant road accidents
- some minor works
by Phill » Fri Dec 14, 2012 10:12 pm
Robs-se wrote:Plan to take it off the road and replace all suspension bushes in the rear and replace bearings and hubs at the front ready for mot in feb.
I have a Vectra SRI and i know its not the same but i have had to change the 4 springs. At the first MOT i got an advisory for slight play in the front wheel bearings, i changed them 2 weeks before the 2nd MOT and i got an advisory for slight play in the front wheel bearings :( When i put her in this year ( I think you know what's coming ) i got an advisory for slight play in the front wheel bearings.
It may be worth giving them a look over mate. Oh and the cd player is s**t, you could go over a fag paper and the cd will skip.
by crinklebender » Sun Dec 16, 2012 11:54 pm
Redo the other wheel arch. Did one with a 3 stage treatment from america last year, and one without for comparison. The treatment side has held up fine, while the other has not. It seems grinding both sides of the arch, etch, clean and epoxy seal can stop the rot.
12" Alpine Type R sub in the back now that the alternator is upgraded.
by crinklebender » Sun Dec 16, 2012 11:58 pm
James_Mould wrote:I'm completely stripping the under neath of the cally and under sealing it,
did that in the summer, took two months to dry out properly.
