guess what iv done
Re: guess what iv done
by v6 steve » Sun Jul 25, 2010 10:42 pm
Ally i thought the underware thing was just being kept between you and i :naughty:
by tazz666 » Sun Jul 25, 2010 11:07 pm
looks like it will be the drain being fixed on saturday then :D
tazz666
by vinny_69 » Tue Jul 27, 2010 7:16 pm
if i dont peek at the first two pages and i guess correct can i have a kitkat?
bad luck Steve :(
vinny_69
by v6 steve » Tue Jul 27, 2010 7:58 pm
vinny_69 wrote:if i dont peek at the first two pages and i guess correct can i have a kitkat?
bad luck Steve :(
if it wasnt for bad luck i would have no luck at all :doh:
by Callyman » Tue Jul 27, 2010 8:00 pm
bad luck Steve :(
I know what that feels like mate, trust me. :alright:
by WmV6 » Tue Jul 27, 2010 8:54 pm
added more leds? dont say youve changed you ice lol :naughty:
WmV6
by WmV6 » Tue Jul 27, 2010 8:56 pm
yip they were cheched cause i was there
WmV6
by v6 steve » Tue Jul 27, 2010 9:03 pm
WmV6 wrote:yip they were cheched cause i was there
yee they were checked but they dont look right now :(
by WmV6 » Tue Jul 27, 2010 9:06 pm
must be to much torque mate
WmV6
by stevo turbo » Wed Jul 28, 2010 8:07 am
you got a modified head or cams in it then? possible double valve springs?
by MarkV6 » Wed Jul 28, 2010 8:58 am
v6 steve wrote:it looks like the rear bank pullys have slipped on the dowel, the engine still starts but dosnt sound good the cam pullys are touching each other :banging:
Can't quite picture how a pulley could 'slip' on a dowel.... Either the dowel has bent, or the pulley has been damaged in some way.
How do you lock the cam pulleys when you change/take the belt off??
Did have a picture somewhere of some cam pulleys where the toothed part had sheared off from the 'hub' part of the pulley because they'd used grips to hold the pulleys together.
I used to own this Calibra...
I now own this one.
Xbox live gamertag IcedSage
by k1nty » Wed Jul 28, 2010 9:50 am
are the dowels a good fit in pulleys to start with?
k1nty
by v6 steve » Wed Jul 28, 2010 7:21 pm
i use a locking kit when i did the belt, i think the problam is that i got my pullys powder coated if i had lef the old ones on then it wouldnt have happend, ill try and get a pic up of the pully that slipped the last time you can see where the dowel has made the round hole oval, once i get the front of the engine ill take a pic of the pullys that have moved this time,
by v6 steve » Sun Aug 01, 2010 12:02 am
got the Drain fixed today thanks again to the A team you know who they are, it was the dowel that has moved it looks like we never tightened the cam pully bolts up propaly when we first put them on :banging:
they are a bit too close
note the shape of the hole around the dowel
by stevo turbo » Sun Aug 01, 2010 3:21 pm
OOPS! expensive mistake and easy to do. but all good to hear its been fixed again :)
