guess what iv done
Re: guess what iv done
Ally i thought the underware thing was just being kept between you and i
if i dont peek at the first two pages and i guess correct can i have a kitkat?
bad luck Steve
bad luck Steve
vinny_69 wrote:if i dont peek at the first two pages and i guess correct can i have a kitkat?
bad luck Steve
if it wasnt for bad luck i would have no luck at all
v6 steve wrote:vinny_69 wrote:if i dont peek at the first two pages and i guess correct can i have a kitkat?
bad luck Steve
I know what that feels like mate, trust me.
WmV6 wrote:yip they were cheched cause i was there
yee they were checked but they dont look right now
you got a modified head or cams in it then? possible double valve springs?
- Club Member
v6 steve wrote:it looks like the rear bank pullys have slipped on the dowel, the engine still starts but dosnt sound good the cam pullys are touching each other
Can't quite picture how a pulley could 'slip' on a dowel.... Either the dowel has bent, or the pulley has been damaged in some way.
How do you lock the cam pulleys when you change/take the belt off??
Did have a picture somewhere of some cam pulleys where the toothed part had sheared off from the 'hub' part of the pulley because they'd used grips to hold the pulleys together.
I used to own this Calibra...
I now own this one.
Xbox live gamertag IcedSage
I now own this one.
i use a locking kit when i did the belt, i think the problam is that i got my pullys powder coated if i had lef the old ones on then it wouldnt have happend, ill try and get a pic up of the pully that slipped the last time you can see where the dowel has made the round hole oval, once i get the front of the engine ill take a pic of the pullys that have moved this time,
got the Drain fixed today thanks again to the A team you know who they are, it was the dowel that has moved it looks like we never tightened the cam pully bolts up propaly when we first put them on
they are a bit too close
note the shape of the hole around the dowel
OOPS! expensive mistake and easy to do. but all good to hear its been fixed again
- Club Member
