The one little thing that irritates you about your car
Re: The one little thing that irritates you about your car
The amount of work I have to do to keep it red.
Mark1 wrote:The amount of work I have to do to keep it red.
get it resprayed its easier
Not forgetting the white instrument cluster when you can't see how fast you are going at dusk.
Cavalier CDi 96 Grey
Cavalier SRi 93 Satin Red
Cavalier Mk2 CD130 86 White
One thing that irritates me is all the niggly problems its developed over the last few months and i've not had the time or weather to fix them
The Temp Gauge on the Dash, in relation to the Operating Temp on the V6...
The Reading on the V6 gets so close to the RED Zone...
EddeyDancer wrote:The Reading on the V6 gets so close to the RED Zone...
At least it is not 'Turbo' close......
GreyDJ wrote: At least it is not 'Turbo' close......
I've got 'No idea' what is meant by 'Turbo' close!!!
Please clarify!!!
i hate the fact that its a bottomless pit and cost a forturne theres always something else to do, but shes worth it
ian
the one thing that niggles me is that there isnt just one thing that niggles me about my calibre
EddeyDancer wrote:GreyDJ wrote: At least it is not 'Turbo' close......
Please clarify!!!
That's when it seems to regard hovering next to the red zone as normal and you have to put the heater on full on a warm day to help the radiator fan cool the engine down.
I suspect that the radiator is not really big enough.
I have already removed the Thermostat, for little results...
Now I'm going to fit a Radiator Fan Switch, that kicks in at 10 degrees less, than the standard...
The Radiator isn't all that old either...
EddeyDancer wrote:I have already removed the Thermostat, for little results...
I tried that when i had problems with my 2ltr ecotec. the problem with the one i had was because it kicks in 10 degrees less it will try to cool the water 10 degrees less than normal and while driving the car the temp never got down to that to switch off the radiator fan. I went through 2 fans before i changed back. I changed the thermostat and radiator and that worked for me, i did notice that the radiator fins were full of all sorts dead flies etc. it may be worth removing the radiator to clean it.
No problems when driving it.
Main gripe is that garages don't like having to deal with it, as its a diagnostic headache. one mechanic said "sorry not dealing with v6, too complicated !"
crinklebender wrote:No problems when driving it.
nothing complicated about a v6 fuel + air + spark = go go go
