The one little thing that irritates you about your car
Re: The one little thing that irritates you about your car
by Mark1 » Fri May 25, 2012 4:18 pm
The amount of work I have to do to keep it red.
by Allys Cally » Fri May 25, 2012 4:53 pm
Mark1 wrote:The amount of work I have to do to keep it red.
get it resprayed its easier :lol:
by GreyDJ » Sat May 26, 2012 12:48 am
Not forgetting the white instrument cluster when you can't see how fast you are going at dusk.
Cavalier CDi 96 Grey
Cavalier SRi 93 Satin Red
Cavalier Mk2 CD130 86 White
by Robs-se » Sat May 26, 2012 3:12 am
One thing that irritates me is all the niggly problems its developed over the last few months and i've not had the time or weather to fix them :evil:
by EddeyDancer » Sat May 26, 2012 3:24 am
The Temp Gauge on the Dash, in relation to the Operating Temp on the V6... :pray:
by EddeyDancer » Sat May 26, 2012 9:19 am
The Reading on the V6 gets so close to the RED Zone...
by GreyDJ » Sat May 26, 2012 9:47 am
EddeyDancer wrote:The Reading on the V6 gets so close to the RED Zone...
At least it is not 'Turbo' close......
by EddeyDancer » Sat May 26, 2012 9:54 am
GreyDJ wrote: At least it is not 'Turbo' close......
I've got 'No idea' what is meant by 'Turbo' close!!!
Please clarify!!! :think:
by ian » Sat May 26, 2012 10:02 am
i hate the fact that its a bottomless pit and cost a forturne theres always something else to do, but shes worth it
ian
by v6 steve » Sat May 26, 2012 10:08 am
the one thing that niggles me is that there isnt just one thing that niggles me about my calibre :lol:
by GreyDJ » Sat May 26, 2012 1:07 pm
That's when it seems to regard hovering next to the red zone as normal and you have to put the heater on full on a warm day to help the radiator fan cool the engine down.
I suspect that the radiator is not really big enough.
by EddeyDancer » Sat May 26, 2012 7:52 pm
I have already removed the Thermostat, for little results...
Now I'm going to fit a Radiator Fan Switch, that kicks in at 10 degrees less, than the standard...
The Radiator isn't all that old either...
by Phill » Sat May 26, 2012 9:31 pm
EddeyDancer wrote:I have already removed the Thermostat, for little results...
I tried that when i had problems with my 2ltr ecotec. the problem with the one i had was because it kicks in 10 degrees less it will try to cool the water 10 degrees less than normal and while driving the car the temp never got down to that to switch off the radiator fan. I went through 2 fans before i changed back. I changed the thermostat and radiator and that worked for me, i did notice that the radiator fins were full of all sorts dead flies etc. it may be worth removing the radiator to clean it.
by crinklebender » Mon May 28, 2012 1:52 am
No problems when driving it.
Main gripe is that garages don't like having to deal with it, as its a diagnostic headache. one mechanic said "sorry not dealing with v6, too complicated !"
by v6 steve » Mon May 28, 2012 7:18 pm
crinklebender wrote:No problems when driving it.
nothing complicated about a v6 fuel + air + spark = go go go
