calibra le
calibra le
what engine model is in my 2.0 16v turbo ltd edition
Re: calibra le
is that the red top if not whats the diffrence
Re: calibra le
the red top is a c20xe and dosent have a turbo
Re: calibra le
The 'Redtop' is the (C)2.0XE with normally aspirated fuel injection. The C20LET is basically a slightly modified XE with turbo'd injection.
Cavalier CDi 96 Grey
Cavalier SRi 93 Satin Red
Cavalier Mk2 CD130 86 White
Re: calibra le
what makes them differant apart from the turbos then ????????????????
Re: calibra le
GreyDJ wrote:The 'Redtop' is the (C)2.0XE with normally aspirated fuel injection. The C20LET is basically a slightly modified XE with turbo'd injection.
got you thanks guys
Re: calibra le
the c20let has lower compression than the c20xe
Re: calibra le
My LE is a Redtop.
Also they have sodium filled valves, different cams and oil feed. The cat is meant to be Steel and the exhaust too.
Sean
SE5 Turbo
LE 07
LE 16
LE41
Turbo
Another Turbo
Se7
V6
16V
16V XEV
8v
SE5 Turbo
LE 07
LE 16
LE41
Turbo
Another Turbo
Se7
V6
16V
16V XEV
8v
- Gold Member
Re: calibra le
oil return in the block from the turbo
- Club Member
Recalibrate
se5 wrote:My LE is a Redtop.
So is mine but the c20xe is commonly know as the "Red Top"
Re: calibra le
The nickname 'redtop' comes from nothing more than the Red L shaped plug cover.
Users browsing this forum: No registered users and 58 guests
