calibra le
calibra le
by rich30mex » Sun Apr 17, 2011 9:37 pm
what engine model is in my 2.0 16v turbo ltd edition
Re: calibra le
by rich30mex » Sun Apr 17, 2011 9:45 pm
is that the red top if not whats the diffrence
Re: calibra le
by v6 steve » Sun Apr 17, 2011 9:51 pm
the red top is a c20xe and dosent have a turbo
Re: calibra le
by GreyDJ » Sun Apr 17, 2011 9:53 pm
The 'Redtop' is the (C)2.0XE with normally aspirated fuel injection. The C20LET is basically a slightly modified XE with turbo'd injection.
Cavalier CDi 96 Grey
Cavalier SRi 93 Satin Red
Cavalier Mk2 CD130 86 White
Re: calibra le
by rich30mex » Sun Apr 17, 2011 9:53 pm
what makes them differant apart from the turbos then ????????????????
Re: calibra le
by rich30mex » Sun Apr 17, 2011 9:54 pm
GreyDJ wrote:The 'Redtop' is the (C)2.0XE with normally aspirated fuel injection. The C20LET is basically a slightly modified XE with turbo'd injection.
got you thanks guys
Re: calibra le
by v6 steve » Sun Apr 17, 2011 9:57 pm
the c20let has lower compression than the c20xe
Re: calibra le
by LE16 » Tue Apr 19, 2011 11:00 am
My LE is a Redtop.
Also they have sodium filled valves, different cams and oil feed. The cat is meant to be Steel and the exhaust too.
Sean
SE5 Turbo
LE 07
LE 16
LE41
Turbo
Another Turbo
Se7
V6
16V
16V XEV
8v
Re: calibra le
by stevo turbo » Tue Apr 19, 2011 7:17 pm
oil return in the block from the turbo
Recalibrate
by v6 steve » Tue Apr 19, 2011 7:46 pm
se5 wrote:My LE is a Redtop.
So is mine but the c20xe is commonly know as the "Red Top"
Re: calibra le
by Callyman » Tue Apr 19, 2011 7:57 pm
The nickname 'redtop' comes from nothing more than the Red L shaped plug cover.
Users browsing this forum: No registered users and 50 guests
