Spent the day
Spent the day
by Robs-se » Thu Nov 17, 2011 12:28 am
Washing and polishing the bollux off the cally to get it back to yellow, and as usual when stepping back to admire the finished product i noticed i had missed a few bits, in the door frames and the the gullies in the hatch, b@gger :x Also anyone recommend any good tar spot remover?
Re: Spent the day
by v6 steve » Thu Nov 17, 2011 12:44 am
tar and glue remover is good i get it from thr autosmart man
Re: Spent the day
by Fraz » Thu Nov 17, 2011 2:43 pm
yes best one is Tardis from Autosmart ..can only get it in 5L though but well worth buying it ...find your local rep and he may give you a smaller size though
Re: Spent the day
by MadOnVaux! » Thu Nov 17, 2011 5:46 pm
WD40 is often overlooked as a tar remover, it does work.
Re: Spent the day
by Fraz » Thu Nov 17, 2011 6:32 pm
so does white spirit if your stuck, but it is better using the right tool for the job
Re: Spent the day
by v6 steve » Thu Nov 17, 2011 8:47 pm
i only paid £7/£8 of 5L of Tardis how much is a 500ml can of wd40 these days :shock:
Re: Spent the day
by Robs-se » Fri Nov 18, 2011 12:16 am
Will look into that cheers
