Spent the day
Spent the day
Washing and polishing the bollux off the cally to get it back to yellow, and as usual when stepping back to admire the finished product i noticed i had missed a few bits, in the door frames and the the gullies in the hatch, b@gger
Also anyone recommend any good tar spot remover?
Re: Spent the day
tar and glue remover is good i get it from thr autosmart man
Re: Spent the day
yes best one is Tardis from Autosmart ..can only get it in 5L though but well worth buying it ...find your local rep and he may give you a smaller size though
Re: Spent the day
WD40 is often overlooked as a tar remover, it does work.
Re: Spent the day
so does white spirit if your stuck, but it is better using the right tool for the job
Re: Spent the day
i only paid £7/£8 of 5L of Tardis how much is a 500ml can of wd40 these days
Re: Spent the day
Will look into that cheers
