Wanted
Wanted
by craigyboy » Fri Oct 16, 2015 10:16 pm
Looking for an inlet cam for a c20xe,can anyone help?
Re: Wanted
by craigyboy » Sat Oct 17, 2015 10:57 am
I replaced all the lifters during the week with ones from Autovaux
and i'm still getting a knocking noise on the inlet cam,so i'm
thinking that the profile might be out in one of the lobes.
I would like to try another cam to see if this cures it.
Re: Wanted
by craigyboy » Sat Oct 17, 2015 11:57 am
There is just the one knocking noise,the rest sound fine.
Re: Wanted
by Callyman » Sat Oct 17, 2015 3:49 pm
measure the lobes.
To still tap you would in theory be able to see which lobe has worn.
Are you sure all the lifters are getting fed oil properly?
Re: Wanted
by craigyboy » Sat Oct 17, 2015 6:48 pm
callyman wrote:measure the lobes.
The noise is coming from just to the right of the oil filler cap
I'll take off the rocker cover and check during the week.
Re: Wanted
by KERR_SE9 » Sun Oct 18, 2015 3:59 pm
I've got one, you can try it out,but I'd need it back
