Wanted
Re: Wanted
I replaced all the lifters during the week with ones from Autovaux
and i'm still getting a knocking noise on the inlet cam,so i'm
thinking that the profile might be out in one of the lobes.
I would like to try another cam to see if this cures it.
Re: Wanted
There is just the one knocking noise,the rest sound fine.
Re: Wanted
measure the lobes.
To still tap you would in theory be able to see which lobe has worn.
Are you sure all the lifters are getting fed oil properly?
Re: Wanted
callyman wrote:measure the lobes.
The noise is coming from just to the right of the oil filler cap
I'll take off the rocker cover and check during the week.
Re: Wanted
I've got one, you can try it out,but I'd need it back
