Need an ECU desperately
Hi all, I am in need of an ECU for my calli. I have a photo attached, does anyone know where I can get 1 from? Cheers.
Re: Need an ECU desperately
Is it from an X20XEV (2.0 16v ecotec)? If so you'll need the ignition collar transponder receiver and key chips too. eBay is a good starting point but am sure if anyone has one they'll post back.
Hi Cliff, thank you for your reply however I do not need these things because my Calli does not have an immobiliser. Cheers, Dutchef
Ok, but you didn't reply which engine you do have - and Year?
I have a ecu from a 97 plate ecotec if that helps you
'Once Driven Forever Smitten'
Hi Cliff, sorry, yes I do have an X20XEV ecotec.
Hey Big Daz, not sure if it helps me, I have a '95 Calibra X20XEV 2.0 16V ecotec engine. Does your ECU have the code 90 508 119 on it?
Cheers,
Dutchef
Cheers,
Dutchef
It had 90 508 290 on it not sure if that matters
Thanks but that one's no good for me.
