Need an ECU desperately
by dutchef » Sat Jan 07, 2017 2:18 am
Hi all, I am in need of an ECU for my calli. I have a photo attached, does anyone know where I can get 1 from? Cheers.
Re: Need an ECU desperately
by Cliff » Sat Jan 07, 2017 4:47 pm
Is it from an X20XEV (2.0 16v ecotec)? If so you'll need the ignition collar transponder receiver and key chips too. eBay is a good starting point but am sure if anyone has one they'll post back.
by dutchef » Mon Jan 09, 2017 7:16 am
Hi Cliff, thank you for your reply however I do not need these things because my Calli does not have an immobiliser. Cheers, Dutchef
by Cliff » Mon Jan 09, 2017 7:20 am
Ok, but you didn't reply which engine you do have - and Year?
by BigDaz » Mon Jan 09, 2017 3:14 pm
I have a ecu from a 97 plate ecotec if that helps you
'Once Driven Forever Smitten'
by dutchef » Tue Jan 10, 2017 1:33 am
Hi Cliff, sorry, yes I do have an X20XEV ecotec.
Hey Big Daz, not sure if it helps me, I have a '95 Calibra X20XEV 2.0 16V ecotec engine. Does your ECU have the code 90 508 119 on it?
Cheers,
Dutchef
by BigDaz » Tue Jan 10, 2017 7:28 am
It had 90 508 290 on it not sure if that matters
by dutchef » Tue Jan 10, 2017 7:40 am
Thanks but that one's no good for me.
