urgent help needed
urgent help needed
ok went to leeds today all well, on the way home the little light bulb warning lamp kept coming on and off when i got home checked the lights passenger side dipped beam and indicator not working. went to shop for new bulbs changed them but still no good on way home from the shop brake light warning lit, i had lost all the brake lights and indicators checked the fuse and it had blown, changed it all working except the passenger front dipped beam still not working
help
help
chief
<!--quoteo--><div class='quotetop'></div><div class='quotemain'><!--quotec-->connector on the back of the bulb loose?....<!--QuoteEnd--></div><!--QuoteEEnd-->
nope!
<!--quoteo--><div class='quotetop'></div><div class='quotemain'><!--quotec-->You forgot to turn the eingine on? ? ?<!--QuoteEnd--></div><!--QuoteEEnd-->
:icon_mrgr nope:icon_mrgr
well as some of you may have seen the other day, i've just lowered my baby(ahhhhhhhhh i hear you say) well as the track rod thingies lifted when i lowered her they caught a bit of loom which shouldnt (i dont think) be there. had a good look round and found four or five wires have been split(some cut completely) so there you go, a problem that probably wouldnt have happened 9 times out of 10. a lesson to be lernt?????
yes, give yourself plenty of time and dont end up lowering your car in the dark:eek:
nope!
chief
