urgent help needed
urgent help needed
by chief » Fri Dec 09, 2005 5:55 pm
ok went to leeds today all well, on the way home the little light bulb warning lamp kept coming on and off when i got home checked the lights passenger side dipped beam and indicator not working. went to shop for new bulbs changed them but still no good on way home from the shop brake light warning lit, i had lost all the brake lights and indicators checked the fuse and it had blown, changed it all working except the passenger front dipped beam still not working
help
chief
by lammy » Fri Dec 09, 2005 6:02 pm
I'd check the connection first..one of mine kept refusing to come on and i found that it was a problem with the fixing at the back (the clip) that wasn't holding the bulb holder securely enuogh. After a little tweaking it was sorted...i hope thats all it is?
SE9
by chief » Fri Dec 09, 2005 6:10 pm
all was well last night, cant see whats wrong
chief
by chief » Fri Dec 09, 2005 9:13 pm
ok this is now solved, but i cant fix it till tuesday. anyone want to hazard a guess at what was wrong????
chief
by lammy » Sat Dec 10, 2005 12:41 am
connector on the back of the bulb loose?....
SE9
by Alcofrolic » Sat Dec 10, 2005 2:51 am
You forgot to turn the eingine on? ? ?
Alcofrolic
by chief » Sun Dec 11, 2005 12:12 am
<!--quoteo--><div class='quotetop'></div><div class='quotemain'><!--quotec-->connector on the back of the bulb loose?....<!--QuoteEnd--></div><!--QuoteEEnd-->
nope!
<!--quoteo--><div class='quotetop'></div><div class='quotemain'><!--quotec-->You forgot to turn the eingine on? ? ?<!--QuoteEnd--></div><!--QuoteEEnd-->
:icon_mrgr nope:icon_mrgr
well as some of you may have seen the other day, i've just lowered my baby(ahhhhhhhhh i hear you say) well as the track rod thingies lifted when i lowered her they caught a bit of loom which shouldnt (i dont think) be there. had a good look round and found four or five wires have been split(some cut completely) so there you go, a problem that probably wouldnt have happened 9 times out of 10. a lesson to be lernt?????
yes, give yourself plenty of time and dont end up lowering your car in the dark:eek: :nono:
chief
