Warning left lights on buzzer
Riggghhhtt, got ya. I can't even check at the mo cos I've left my Cally at work but if you look on the back of the fuse box cover then it should show it's location. The guide on CavWeb says it's on the left and the Vauxhall partnumber is 90 240 665 (this will be embossed into the top of the relay).
SteveU
90 464 777 is the number I think it might be. It seems to be top left. All the other relays are working for other things and the map on the cover shows this. The one I was looking at the cover has a W as the symbol.
If you have any idea's. Now being here in SA and the calibra being as rare as it is. Can I not just get one from an Astra or something or are they all universal???
alisdair
