Windows not working
Windows not working
by Green Machine » Tue Apr 04, 2006 11:48 pm
I have just installed a trip computer into my 16v Eco.
To do this i removed the centre console to cut the coin holder out to make way for the switch, i have now connected it all back up, followed the reprograming instructions in the Haynes manual for the windows, but they r dead. The light is on but the windows don't move.
Anyone else suffered witht he same problem?
Any suggestions?
Lee
Green Machine
by TonyDTM » Tue Apr 04, 2006 11:55 pm
you might have disturbed the multiblock connectors causing a bad or non-connection. Recheck all the connections under there before putting the trim back on. Make sure the clip is fully across and everything is tight and as it should be.
Dunno if anyone else has any ideas but would it hurt to disconnect the battery, reconnect it and hold down the buttons when turning the key to position 2?
TonyDTM
by Green Machine » Tue Apr 04, 2006 11:58 pm
I have checked and checked again all the connections, i will try disconnecting the battery in the morning.
Cheers for the idea.
In the mean time......Any others?.....
Green Machine
by Green Machine » Wed Apr 05, 2006 8:59 am
I have tried that but still no luck, ne more ideas please?
Lee
Green Machine
by Chavtastic » Wed Apr 05, 2006 9:07 am
There are two options here:
You have disturbed the wiring for the switches.
Or both your window motors have failed simultaneously, whilst not in operation.
Which is more likely? [img]/smile.gif[/img]
I'd go back and triple check the wiring to the switches, the distribution block etc...
by Tim2001 » Wed Apr 05, 2006 9:55 am
Might sound a bit daft but have you checked all the fuses as well.
Tim2001
