Windows not working
Windows not working
I have just installed a trip computer into my 16v Eco.
To do this i removed the centre console to cut the coin holder out to make way for the switch, i have now connected it all back up, followed the reprograming instructions in the Haynes manual for the windows, but they r dead. The light is on but the windows don't move.
Anyone else suffered witht he same problem?
Any suggestions?
Lee
Any suggestions?
Lee
Green Machine
you might have disturbed the multiblock connectors causing a bad or non-connection. Recheck all the connections under there before putting the trim back on. Make sure the clip is fully across and everything is tight and as it should be.
Dunno if anyone else has any ideas but would it hurt to disconnect the battery, reconnect it and hold down the buttons when turning the key to position 2?
TonyDTM
