heated seat help
heated seat help
i always presumed that the loom was the same or the wires for the heated seats would be under the carpet some where, even if the seat were not fitted as standed can any one point me in the right direction, and i know i dont need them at the moment, but it would be nice to conect them,
andy1
<!--QuoteBegin-blue redtop+--><div class='quotetop'>(blue redtop)</div><div class='quotemain'><!--QuoteEBegin-->they are there some where,
all calibra's have them as standard<!--QuoteEnd--></div><!--QuoteEEnd-->
Oh no they dont I had to wire them into my old 8v
Afaik the loom that plugs into the seats plugs into somewhere in the drivers footwell up by the ECU
I wired mine straight from the switches cant remember the wire colours thou, easy enough just two wires for each side unless you decide to attatch the earth around the seat area.
Andy
Andy
L337 calibra
andy1
My old SE1 had the wiring. it ran around under the long trim panel and then across the front of the raised ridge under under the carpet below the front of the seats on both sides. think it was a brown wire with a connector on it.
Rob
Rob
