Funny goings on
How do I drop the boost?
by DBV6 » Mon Oct 04, 2004 8:10 am
Last Wed dropped the kids at school and starting up again the alternator light was on.
No problems at all running, the faster I went the dimmer the light got, the more elecs I turned on the brighter it got.
BUT started fine every time and volt gauge in car showing healthy 14 volts always
Yesterday morning got in started up, the light's not on any more (apart from ignition on but not started as it should be)
Anybody any ideas?
DBV6
by Dan Willis » Mon Oct 04, 2004 9:49 am
Sounds like your alternator may either be on it's way out or the belt isn't doing it's job.
Smurf (Neil) and some other V6 owners have had similar problems - was time for a new alternator.
Dan
by DBV6 » Mon Oct 04, 2004 10:16 am
Cheers Dan
DBV6
by Tim2001 » Mon Oct 04, 2004 12:24 pm
When the light glows very bright its generally a new alternater required as dan says. the reason its not on any more is generally the bulb itself blows due to too much current coming through. The alternater has a regulater inside which is generaly the bit that goes get a garage to check the voltage/amperage that you are charging at and dont rely on the internal voltmeter
Tim2001
by Robert_Dale » Mon Oct 04, 2004 1:34 pm
yup
happened similar on me eight valve - new alternator mate
Robert_Dale
by DBV6 » Tue Oct 05, 2004 6:27 am
but the bulb is still working....ignition on bulb on, engine on bulb off
DBV6
