Brake / wheel prob
Brake / wheel prob
My v6 has started vibrating when braking. its fairly bad at around 60mph, enough to judder the steering wheel and generally feel unsafe. At lower speed ,say 30mph, the brakes have a sort of on off effect, making the car feel like its rocking back and forth slightly. Theres no grinding noise like the pads are going.Also the brakes dont feel as powerfull as they used to.
Any ideas?
Thanks...... Ste
Any ideas?
Thanks...... Ste
metal-ste
Sounds like you need new disc's.
I've got this also, I know the tracking is spot on as i've only recently had it done, spiggots in place and wheels balanced...my next port of call was to change the discs as I thought that might solve the slight wobble, however wouldn't there be some feeling from the brake pedal if the discs were warped?
SE9
Ive had discs from this chap on ebay :
<a href="http://stores.ebay.co.uk/sportbrakediscs" target="_blank">http://stores.ebay.co.uk/sportbrakediscs</a>
You can have them in any combination, grooved or drilled or both.
Mine were just grooved and were excellent for the price and worked ok with standard pads.
[img]/smile.gif[/img]
