Brake / wheel prob
Brake / wheel prob
by metal-ste » Sat Dec 09, 2006 7:58 pm
My v6 has started vibrating when braking. its fairly bad at around 60mph, enough to judder the steering wheel and generally feel unsafe. At lower speed ,say 30mph, the brakes have a sort of on off effect, making the car feel like its rocking back and forth slightly. Theres no grinding noise like the pads are going.Also the brakes dont feel as powerfull as they used to.
Any ideas?
Thanks...... Ste
metal-ste
by RobbieV » Sat Dec 09, 2006 8:01 pm
Check the disc's
by Mark1 » Sat Dec 09, 2006 8:22 pm
Sounds like you need new disc's.
by Twist » Tue Dec 12, 2006 1:47 am
Probably warped discs M8 check them out [img]/biggrin.gif[/img]
Twist
by metal-ste » Tue Dec 12, 2006 8:47 pm
Yeah will do.
Whats best to get, Standard v6 discs or perhaps some grooved or drilled discs?
Can you tell any difference between them?
metal-ste
by lammy » Tue Dec 12, 2006 10:22 pm
I've got this also, I know the tracking is spot on as i've only recently had it done, spiggots in place and wheels balanced...my next port of call was to change the discs as I thought that might solve the slight wobble, however wouldn't there be some feeling from the brake pedal if the discs were warped?
SE9
by Shrubie » Tue Dec 12, 2006 10:24 pm
I had EDC grooved discs on my old cav and they were great!! Noisey but certainly did the job!! Ive never had drilled before but ive heard they can be easy to warp!!
If you do go for grooved discs its best to uprate the pads too cos standards wont last long with the grooved discs!!!
Shrubie
by RobbieV » Tue Dec 12, 2006 10:31 pm
Ive had discs from this chap on ebay :
<a href="http://stores.ebay.co.uk/sportbrakediscs" target="_blank">http://stores.ebay.co.uk/sportbrakediscs</a>
You can have them in any combination, grooved or drilled or both.
Mine were just grooved and were excellent for the price and worked ok with standard pads.
[img]/smile.gif[/img]
Users browsing this forum: Google [Bot] and 2 guests
