tyre pressures
Re: tyre pressures
by stevo turbo » Thu Jun 02, 2011 6:06 pm
all services i do at work i use 32psi, espically when you look at it this way,
what temp is it on the day of testing? do you adjust accordingly?
i watched a psi monotring system on a insignia going down the road and i a 3 mile road test it went up 5 psi all round!
i really dont think 2psi here or there makes a big difference
Re: tyre pressures
by Callyman » Thu Jun 02, 2011 6:06 pm
mmm, i will change the turbo to 34/32 as the sub box in the boot weighs a ton.
having 32 all round does seem to be wearing evenly though.
Re: tyre pressures
by BazV6er » Wed Jun 08, 2011 7:55 am
i run 34 front ,31 rear
